been hapenin for a few days now...
im not 100% sure it is the turbo im just asuming it is as the noise only seems to hapen when im at about 4/5psi... im stil geting full boost and holds though but it whines from 4-11psi dosnt whine below 4psi.
i thought it might be an intercooler hose not tight so i had all my pipes off last nice,gave them a clean then put them back on this morning and made sure they were tight.
dunno if this will help but on my way home from work today one off the pipes blew off..
i will say that it has got a bit of a dodgy jublee clip thought as i tightnd it to much then it went back(if that makes sens)..the pipe that blew off was the one with the dodgy clip
anyone no what this could be?
my first hybrid made a high pitched noise the same as your explaining but mines was hitting full boost then dropping off, sent it off to get rebuild and it was a bearing that had gone
take off your air filter and check for shaft play
wtf, my one makes a nice whine like a super charger lol i thought it was normal. You have me worrying now :S
mine has re-circulation valve still, don't have any idea what that does (time to google) lol
So you have found oil in or on the cold side of your intercooler pipework?
If its on the inside id think a serious turbo issues as it would have blow oil all the way through you intercooler.
But you have said you took your air filter off to find oil on the cold side? Taking your air filter off shows you the turbo, not your cold side pipwork?
i dont no anything about turbos tbh..
the oil was in and around the air filter side of the turbo... but today i also found it in the hard pipe of the turbo
got another turbo on the way now anyway lol
