Dan Evans Posted March 6, 2010 Posted March 6, 2010 http://cgi.ebay.co.uk/TOYOTA-4EFTE-CRANKSH...=item45f15361b2just looking at these, there the cheapest set I've found so far but want to make sure they are the correct ones??Anyone know?cheers Quote
micky boy Posted March 6, 2010 Posted March 6, 2010 Thats what i've seen other people use,but get some more info be for you buy them Quote
ToyotaTech15 Posted March 6, 2010 Posted March 6, 2010 They are undersized bearings, have you had the crank reground atol? if so the machine shop will tell you what size you needGary Quote
Dan Evans Posted March 6, 2010 Author Posted March 6, 2010 no mate, crank is not re-grounded, leaving it as ischeers Quote
ToyotaTech15 Posted March 6, 2010 Posted March 6, 2010 Well it says that they can be supplied at 0.25mm and 0.55mm so maybe best contacting the seller to make sure he has the right size for you engine before orderingGary Quote
