pogo29 Posted March 10, 2010 Posted March 10, 2010 I am thinking of getting some second hand wheels, maybe from a breakers or ebay.What wheels fit?? for example if i go to ebay and look for glanza wheels im not going to get many hits, but if fiesta aftermarket wheels fit, then im going to have a lot more options. so the more options of suitable wheels the better.thanks. Quote
lukEp Posted March 10, 2010 Posted March 10, 2010 4 stut ford wont fit there pcd is 108mm the starlets are 100mm. What fits: corolla, mr2 (4stud), vauxhalls, vw........ loads when you search on ebay type in 4x100 you want an offset of 38 max, 37 to be safe or they will rub mine are 38 and with toyo t1r on 195/50/15 dont rub but i also have 1 budget tyre and it rubs just. if going for aftermarket alloys get some spigot rings to locate the wheel on the hub stops steering wheel wobble at speed. Quote
pogo29 Posted March 10, 2010 Author Posted March 10, 2010 4 stut ford wont fit there pcd is 108mm the starlets are 100mm. What fits: corolla, mr2 (4stud), vauxhalls, vw........ loads when you search on ebay type in 4x100 you want an offset of 38 max, 37 to be safe or they will rub mine are 38 and with toyo t1r on 195/50/15 dont rub but i also have 1 budget tyre and it rubs just. if going for aftermarket alloys get some spigot rings to locate the wheel on the hub stops steering wheel wobble at speed.thanks for your help Quote
