Spoonz Posted March 21, 2010 Posted March 21, 2010 Hey just havin a chat with a mate and was wondering will a lightweight flywheel creat less flywheel power? has hes thinking of gettin one fitted and was just curious, oviously its befifical to the overal performance of the car but was just wondering about the power figure Quote
Wantaglanz Posted March 21, 2010 Posted March 21, 2010 i would of thought so as the engine wont need to work as hard to turn it if its lighter? so would mean more bhp? i think lol might be wrong! Quote
Spoonz Posted March 21, 2010 Author Posted March 21, 2010 yea i could see what your sayin i read on here or maybe tgtt somewhere that it will make less power on a dyno for watever reasons but oviously help with goin up the revs in the car etc so my question really is will it give a less power figure on a dyno to havin a normal standard flywheel Quote
shorty Posted March 21, 2010 Posted March 21, 2010 wouldnt of thought so as its less drag/resistance. its less of a power thing and more of a revs thing i have a JUN one on my V and it revs a lot more freely than my last V that didint have one. it wouldnt reduce atf horsepower as thats due to the engine/setup/tune etc not the wieght of the fly Quote
Spoonz Posted March 21, 2010 Author Posted March 21, 2010 ahh ok yea thats what i thought but didnt wanna say summut prob would have got slated lmao thanks for the replys Quote
Dean @RW-Developments Posted March 21, 2010 Posted March 21, 2010 as far as im aware, the revs will rise quicker! im not sure if it will alter the bhp but they definatly loose torque! Quote
Spoonz Posted March 21, 2010 Author Posted March 21, 2010 ahh see that explains something that i been wondering about lol how much torque do they lose like has in a rough % wise Quote
mr karnage Posted March 21, 2010 Posted March 21, 2010 a lighter flywheel will reduce rotational mass but you are supposed to lose momentum going up hills compared to a standard but makes heel and toe even better. also the car will rev more freely Quote
Nick@TD.co.uk Posted March 22, 2010 Posted March 22, 2010 Yeah as said, peak BHP is suppose to increase (although very minimal) the Torque will suffer slightly but all these slight changes in BHP and Torque you wont really notice, the main difference you will notice is that the engine will be alot easier to rev up so will tend to like revving easier so Heel and Toe would be better Kind Regards,Nick JonesTuning Developments LTDWorkshop Landline - 01925 822266TuningDevelopments@Hotmail.comwww.TuningDevelopments.co.uk Quote
motion Posted March 22, 2010 Posted March 22, 2010 read this:http://www.pumaracing.co.uk/FLYWHEEL.htm i also have a question, i have bought a oem flywheel which is lightend and weights 5.3 kg.how much weights the stock 4e-fe flywheel? i heard somethimng about 6.7 kg will i notice any difference when i change it? Quote
Spoonz Posted March 22, 2010 Author Posted March 22, 2010 i really was just wondering if u wud notice it on a dyno lol but alot of useful info thanks dudes Quote
scot-ish Posted March 22, 2010 Posted March 22, 2010 read this:http://www.pumaracing.co.uk/FLYWHEEL.htm i also have a question, i have bought a oem flywheel which is lightend and weights 5.3 kg.how much weights the stock 4e-fe flywheel? i heard somethimng about 6.7 kg will i notice any difference when i change it?i wouldn never fit a stock flywheel that has been lightened, too many dangers, and thinking of the way the engine-gearbox are aligned, if it fails, its coming through the dash into your face.on a higher note, if thats your car in the signature, its pretty sweet Quote
motion Posted March 22, 2010 Posted March 22, 2010 it is precision balanced, so i dont worry about it.furthermore it was in use since it was lightened and it is still in one piece. yes, its my starlet......cheers Quote
nastyrash 2003 Posted March 23, 2010 Posted March 23, 2010 A lighter flywheel is also a recommendation. Not only do they increase throttle response, they "free up" horsepower by decreasing rotational mass.You can shave your existing flywheel However, this is a controversial issue and if you search will discover how everyone feels about it and the dangers that can come with it. flywheels are normally balanced. flywheels can be lightened within limits and the most effective place for lightening is as far away from the centre as possible. the reason is that force times distance applies and removal of material nearest the starter gear has more effect on the acceleration factor. caution thw Aviod thin sections (less than 0.312in/around 8mm i think) as you risk disintegration in service. now the question is how much iz ok to take off, this will depend entirely on the original thickness of your flywheel but, usually, it will be in the range of 20%-50% of the original weight. if the engine is for race porpose thn all engine internal conponents should be balanced to the last gram for 7000rpm on a continuous basis. and the balancing proces should be crank thn flywheel thn presure plate. always use new clutch plates in my experience as the dowel holes in the presure plate can most of the time wear and not conform to being concentric. this is a masive problem and will thrw everything out. not read the link put on this topic and am sorry if i have just repeated anything, and am talking from my own experience with lightend parts. 1 of the more effective parts to lighten are to use balanced slipper pistons and lightend rods as this helps reduce friction and load on the crank. and this would be true, engineering with mathmatical equations and everything, now we talking peolpe, LOV IT Quote
