brianffc Posted March 21, 2010 Posted March 21, 2010 im starting 2 get blue puffs off smoke only happen the last 2 days and has only dose it in 5th when a take it up 2 85mph Quote
ollie ryan Posted March 21, 2010 Posted March 21, 2010 same as my cars getting matetry changing the PCV valve if not i was told it coukd be the oil seals on the turbo Quote
brianffc Posted March 21, 2010 Author Posted March 21, 2010 same as my cars getting matetry changing the PCV valve if not i was told it coukd be the oil seals on the turbowhere is the pcv valve as a dont no 2 much about turbos Quote
ollie ryan Posted March 21, 2010 Posted March 21, 2010 its a little plastic valve hidden underneath the top mount intercooler Quote
brianffc Posted March 21, 2010 Author Posted March 21, 2010 its a little plastic valve hidden underneath the top mount intercoolerill check that the morra just toke the top mount intercooler off for a front mount Quote
brianffc Posted March 23, 2010 Author Posted March 23, 2010 put a new pcv valve in but still the same can anyone help Quote
Steve GT Posted March 23, 2010 Posted March 23, 2010 well as we all know blue smoke= oilso first question does it smoke on tickover?2nd does it smoke on boost and 3rd does it smoke when cold and then go when its warm? Quote
brianffc Posted March 23, 2010 Author Posted March 23, 2010 well as we all know blue smoke= oilso first question does it smoke on tickover?2nd does it smoke on boost and 3rd does it smoke when cold and then go when its warm?dosent do it at tickover only on boost when warm 4th and 5th gear after 60mph Quote
Steve GT Posted March 23, 2010 Posted March 23, 2010 on boost leads you to maybe turbo seals then dudenot saying for sure but thats normally a sign of a worn turbo Quote
brianffc Posted March 24, 2010 Author Posted March 24, 2010 on boost leads you to maybe turbo seals then dudenot saying for sure but thats normally a sign of a worn turbooh well think its time 2 try a get a new turbo and try that Quote
Steve GT Posted March 24, 2010 Posted March 24, 2010 might be a possibilityif its not bad smoking id keep it till it gets worse IF it gets worse might be okplus keep it on and save for a hybrid i would Quote
brianffc Posted March 24, 2010 Author Posted March 24, 2010 might be a possibilityif its not bad smoking id keep it till it gets worse IF it gets worse might be okplus keep it on and save for a hybrid i wouldits no 2 bad just now only been over the last wk its happen and only at 60mph and over Quote
Steve GT Posted March 24, 2010 Posted March 24, 2010 deffo blue smoke??? and if its not bad i wouldnt worry about it yet. if it did it constantly then id be tempted to replace it if not id leave it be for now lol Quote
brianffc Posted March 24, 2010 Author Posted March 24, 2010 deffo blue smoke??? and if its not bad i wouldnt worry about it yet. if it did it constantly then id be tempted to replace it if not id leave it be for now loldeffo blue smoke not 2 bad be u do c it when u open it up a we bit lol Quote
Steve GT Posted March 24, 2010 Posted March 24, 2010 id leave it for now then in that case it might not get anyworsejust keep a spare 100 quid lying around just incase it does get worse you can buy another one and not be without a car lolother than that i wouldnt worry for now mate Quote
brianffc Posted April 1, 2010 Author Posted April 1, 2010 just done a compression test all 4 are at about 160 2 162 psi is this about rite Quote
ollie ryan Posted April 1, 2010 Posted April 1, 2010 found out my problem is the headgasket going not the turbo oil seals Quote
brianffc Posted April 1, 2010 Author Posted April 1, 2010 found out my problem is the headgasket going not the turbo oil sealsill try the turbo 1st got 1 from some1 for £50 should have it next wk Quote
brianffc Posted April 9, 2010 Author Posted April 9, 2010 just fitted an other turbo but car is still the same anyone no what else it could be Quote
ollie ryan Posted April 9, 2010 Posted April 9, 2010 check your colanthas it stated going a dirty oily colour? Quote
Lawsy Posted April 10, 2010 Posted April 10, 2010 just fitted an other turbo but car is still the same anyone no what else it could betbh you dont know what condition the turbo youve just fitted is in? so the seals could be worn on that? But could be a number of things, could be headgasket but the oil isnt under much pressure atall when draining back through the head to the sump, so the gasket would have to be blown fairly bad for it to be leaking into the combustioin chamber.It could also be valve stem seals, but this would be more noticebale on overrun and from start up. Quote
brianffc Posted April 10, 2010 Author Posted April 10, 2010 tbh you dont know what condition the turbo youve just fitted is in? so the seals could be worn on that? But could be a number of things, could be headgasket but the oil isnt under much pressure atall when draining back through the head to the sump, so the gasket would have to be blown fairly bad for it to be leaking into the combustioin chamber.It could also be valve stem seals, but this would be more noticebale on overrun and from start up.think ive fixed it rocker corver gasket looks like its bn leaking on 2 1 off the plugs the plug was full off oil dryed it off and put sealer on it till a get new gasket was ok on wae home from work Quote
durmz Posted April 10, 2010 Posted April 10, 2010 i didnt personally think this, but been told recently that oil smokes blue only if its been combusted, ie got into a chamber, im not sure on this, but if its true then its not the turbo, so could be headgasket, valve stem seals, things like that.why it could have been ure pcv valve im really unsure :/ Quote
brianffc Posted April 10, 2010 Author Posted April 10, 2010 i didnt personally think this, but been told recently that oil smokes blue only if its been combusted, ie got into a chamber, im not sure on this, but if its true then its not the turbo, so could be headgasket, valve stem seals, things like that.why it could have been ure pcv valve im really unsure :/done pcv valve and turbo all so put mani and de cat on it but was ok on wae home after drying plug off and re sealing rocker gasket the day Quote
