Ashalak Posted March 22, 2010 Posted March 22, 2010 I've been having issues with my speedometer needle since purchasing my car, and I believe damage could of been done by the previous owner whilst fitting a MPH facia. Basically the needle doesn't seem to have tension to return itself to the 0 setting and often the needle, even while stationary doesn't drop below 10mph although if you tap the cover it does move down slightly. I have just ordered a proper cable operated converter and want to re-fit the original KMH speedo facia, but obviously I want to sort the needle out in the process.Has anyone got any suggestions of how I can fix it, or is it something I'll have to get someone more experienced to do? I guess it depends what it is, at this moment in time I am only guess but any help would be greatly appreciated!Thanks. Quote
DavidAshton Posted March 22, 2010 Posted March 22, 2010 Its probably just pushed on too far so its catching on the facia. Quote
Ashalak Posted March 22, 2010 Author Posted March 22, 2010 I did wonder whether that could be the case.. I did read its quite easy to remove the dial cover without removing the entire cluster, any ideas how I can do this? Cheers. Quote
Ashalak Posted April 12, 2010 Author Posted April 12, 2010 Still having issues with this although in partly due to something else now.I tryed to change the facia plate on my EP91 Glanza V from the replaced MPH one to the original KMH facia, I'm doing this as I now have a proper cable operated converter which I'm waiting to put in after I change the facia.I've always had an issue with my speedo however where the needle seems so stick, it doesn't ever seem to go back down to 0 when it should do and it tends to stick at varying places. I was told it could be catching on the facia but after having looked tonight I can't see that it does.This however is only part of the issue as when I came to removing the needle, to change the facia I couldn't seem to get the needle off. I was told it is just a push fit, but I had to exert a fair amount of force and it still didn't seem to want to come out, but equally I didn't want to break it. Is there something I am missing? Is it possible that whoever originally changed the facia damaged the needle?Also, I'm just concerned about the fuel gauge which I accidentally caught the needle on.. I didn't remove it, just touched it slightly in the process of trying to remove the speedo needle. I made sure it was roughly where it was, could I have cocked this up or will it settle back to where it needs to be on its own?Many thanks in advance for any help!Thanks again. Quote
