starletgt troy Posted March 22, 2010 Posted March 22, 2010 Hello im looking for a little bit of advice.... i have a ported standard manifold and a stainless steel manifold which i got off ebay. When i looked at the stainless one the diameter of the runners are greater than the exhaust output on the cyclinder head, so would this not cause lag in throttle response and decrease in torque?So hence my confusion about which manifold to use??Cheers in advance Troy Quote
Glanza_cl Posted March 22, 2010 Posted March 22, 2010 when you say stainless steel one off ebay i hope you haven't gone and got yourself an autoFAIL autobanh mani? if it's a Jperformance then you will be fine mate, if you happen to have got the autofail mani i would just bin it.the slightly larger diameter pipe work wont have any effect bud as the less restrictive design will make up the flow Quote
starletgt troy Posted March 22, 2010 Author Posted March 22, 2010 Haha no i made that mistake previous lasted all about a month along with the same make decat lol Okay thats good to hear cheers for you help Quote
ForresGlanza Posted March 22, 2010 Posted March 22, 2010 sorry to hijack bud but I have an autobahn mani and is seriously cracked. I need new stainless mani just to last a while. are the ones off ebay that are 3mm ok? Quote
starletgt troy Posted March 22, 2010 Author Posted March 22, 2010 sorry to hijack bud but I have an autobahn mani and is seriously cracked. I need new stainless mani just to last a while. are the ones off ebay that are 3mm ok?Hello yes thats the one that i have got not yet fitted it, so cant quote how long it will last but i also got a braced decat which been told helps it last.The quality of the welds and the wall thickness is alot better than the autobahn one though hope that helps Quote
ForresGlanza Posted March 22, 2010 Posted March 22, 2010 Thanks thats a great help dude. I've already got a braced decat so should be ok there. Quote
micky boy Posted March 22, 2010 Posted March 22, 2010 Personaly i wouldn't buy any manifold off ebay whether it be autobahn/jperformance they are all shit...I would save up and buy a Zisco manifold it will save you money in the long run Quote
ForresGlanza Posted March 22, 2010 Posted March 22, 2010 well that was the plan but i crashed a couple weeks ago:( so gotta go cheap. Quote
Carl. Posted March 22, 2010 Posted March 22, 2010 i made the misstake of gettin a cheap one of ebay that was supposed to have 3mm thick runners thinking it should be ok if its 3mm. once i got it i checked thickness with a micrometer and it was 1.3mm not 3mm. got straight on tinternet nd got a refund.they agreed to refund me straight away without question as if they knew that theyd sent me the thin monkey metal shit and was hoping i wouldnt check. Quote
Carl. Posted March 22, 2010 Posted March 22, 2010 i made the misstake of gettin a cheap one of ebay that was supposed to have 3mm thick runners thinking it should be ok if its 3mm. once i got it i checked thickness with a micrometer and it was 1.3mm not 3mm. got straight on tinternet nd got a refund.they agreed to refund me straight away without question as if they knew that theyd sent me the thin monkey metal shit and was hoping i wouldnt check.also it even said on the listing "3mm thick not 1.3" which is the reason why i checked it because it sounded dodgy Quote
