hi.
i hav a glanza and i have a big problem with it. its smoking big time. i have got thick white smoke coming out the exhaust. I changed the turbo and the problem is stil there. I have got oil coming out from underneath the bonnet somewhere too. i cant figure out wot it is? does anyone know wot it cud be.
Guest cheshireglanza
^^ forgot i had to come see you are you home bout 8 dude will have look for you
White smoke from the exhaust if not your turbo may be your headgasket mate!? :rolleyes:
Dont continue to run it. get your head skimmed and a new gasket in there and see if it solves your issues!
prob your ring's, but start with the simple stuff, compression check then a wet compression check, if it seems ok, try a new pcv valve which is on the rocker cover and connects back up to the inlet mani, only 25 quid ish
how does the car drive? is is sluggish ?
the car drives sluggish but it runs. has anyone got any engines for sale?
