dale10ellis10 Posted April 10, 2010 Posted April 10, 2010 Since my car is up and running again ive found a place nearby that can map the emanage which is good But i have a slight problem, im getting them to fit it aswell and i took it in to show them what ive got and they have only ever used a plug and play harness? I dont have a clue what the wires i have got that connect to the emanage are for, they are really long and carnt imagine why they need to be that long, surely they just need to be connected to the wiring loom next to the old ecu?Any help appreciated.. or do you have any clear instructions to present to the garage on how to fit and wire in. Or do i need a plug and play harness?Pictures: Quote
WallaceGlanza Posted April 12, 2010 Posted April 12, 2010 You can't buy a "plug and play harness" it would need to be an extension harness that someonehas already wired the emanage harness into, it's a simplebit of wiring for an electrician, especially with a wiring diagram.... Quote
parko Posted March 23, 2011 Posted March 23, 2011 You can't buy a "plug and play harness" it would need to be an extension harness that someonehas already wired the emanage harness into, it's a simplebit of wiring for an electrician, especially with a wiring diagram....does anyone know if this is the same wiring diagram for an ep82 starlet? cheers Quote
_shaun_ Posted March 23, 2011 Posted March 23, 2011 does anyone know if this is the same wiring diagram for an ep82 starlet? cheersthe pin out on ep82 ecu is 2 plugs instead of 3 so no but if u get a copy of the pin outs on a ep91 and a ep82 it should be pretty easy to work out Quote
parko Posted March 24, 2011 Posted March 24, 2011 the pin out on ep82 ecu is 2 plugs instead of 3 so no but if u get a copy of the pin outs on a ep91 and a ep82 it should be pretty easy to work outcheers shaun. going to spend longer fishing out the right wiring diagrams than installing the e manage! Quote
