My underbrace (which along with the top strut brace has improved the handling no end) rattles noisily against the standard n/a exhaust. I was wondering; seeing as these are designed for turbo starlets, do they have this problem on glanzas/GTs? If not, would it solve my problem if I bought a standard Glanza/GT exhaust system; or would this not be compatible with an n/a?
Failing this, can anyone suggest anything that I could put between the brace and the exhaust that would stop the rattle but not melt or burn? Thanks in advance - James
i think the exhaust is not compatible. as for a material i would suggest thermotec exhaust wrap. you can get it off ebay. a layer of it wraped around the exhaust and strut should work well and its built for use on exhausts so is fully heat proof. hope this helps mate.
ok mate. i have it on my manifold to reduce engine temps. when the exhaust gets hot the wrap smells a bit like biscuits which is an added bonus!
