ryan lang Posted April 12, 2010 Posted April 12, 2010 recently my brake has been sticking so badly that i have to accelerate to get down hills. my dad hada look and found that my piston was corroded so ive bought a new 1 but would like a bit of guidance on how to replace itany help i much appreciated cheers Quote
ryan lang Posted April 12, 2010 Author Posted April 12, 2010 cheers. will i have to bleed the brakes after? Quote
Danturbo4311 Posted April 12, 2010 Posted April 12, 2010 The pistons can sometimes be hard to get out, easiest way to remove them is to remove the brake line & put an air line with adapator in the hole & blow it out (but put a bit of wood in front of the piston so that it doesnt fly off & injure/damage somone or something). As said makesure you clean it up good & check the bore which the piston sits in for scratches etc. Yes you will need to bleed the brakes. Quote
ryan lang Posted April 12, 2010 Author Posted April 12, 2010 alrite cheers fellas. my dad used to make brakes for a living but just wanted to double check because he used to do the for lorries and im guessin theyre quite a bit bigger than mine lol. ill let you know how i get on Quote
