geting my car set up saterday can not wait its been so long ive had to drive it complely off boost cant wait to open it up its probley just me but i swear my mani has the slightest blow will that dramaticly reduce power on the rollers like i said im not 100percent it is im real nervus about the over all power result
if your mani's cracked i wouldnt take it to get mapped really. there going to map it for best possible results for the car which means if your mani's cracked and losing power you wont get your moneys worth out of the map
id get the mani sorted before the mapping sesh :thumbsup:
Guest ep82_girl
id get the mani sorted before the mapping sesh :o
beat me to it :thumbsup: lol
but on a serious note steve is right going to be a waste of money if you map her with a blowing mani. dai_ep82 selling a ported mani
xxx
without trying to be horrible dude and someone correct me if im wrong but its pretty stupid to take a car with a blowing mani to a mapping sesh
id be suprised if the guy maping it wont say its not a good idea yet too lol
Guest ep82_girl
na that aint horrid at all. i see your point as silverglanza could drive all that way to be refused and also could end up with lower power due to it.
honestly i wouldnt take her unless she is 100% its a lot of money to waste
xxx
a blowing mani will give different pressure readings and levels to a normal mani. so the map (if they map it) will differ and will be poor.
you will only potential have to get it remapped once it's sorted as you might find you run rich with the increased pressure and heat build, see if it actually blowing, if it is sort that out first... will save you money in the long run.
Yep, going to sound like a broken record but to me it's pretty obvious that you shouldn't get an engine mapped if everything isn't right!
it doesnt run right atm feels like its holding back and hits fuel cut i thort if i had driven it on boost some one said it could damage my motor didnt want to risk lol and its hard when your on motor way not to hit boost all sorted now guys i got nick to map it and fit new gasket B)
ahhhh right well make sure the blowings 100% fixed or its a waste of money
did you give her a good service before the mapping or not? it would have been a good idea too mate
