string Posted April 21, 2010 Posted April 21, 2010 side mounted seats. how have u done the left bolt? 4 points is two in back. right side to bottom of old belt mount. left side bolts where? Quote
adam starlet87 Posted April 22, 2010 Posted April 22, 2010 have a look on peterloydrallying website. you are looking for a square plate with a nut welded onto it, get that then weld it to your exhaust tunnel and screw a eye bolt into it and then clip the harness to it. hope this helps Quote
string Posted April 22, 2010 Author Posted April 22, 2010 and everyone else has done it this way? i'm unsure. cheers anyway mate Quote
Amjad Posted April 23, 2010 Posted April 23, 2010 I've got one bolt where the Stock seatbelt rail thing is (along the floor) and the other going into the transmission tunnel Quote
string Posted April 23, 2010 Author Posted April 23, 2010 yeah transmission tunnel side i'm stuck with. Is yours in same hole as frame mount? One bolt for both? Or could i use the rear side mounts on seat itself? Cheers craig Quote
Nanglebadger Posted April 23, 2010 Posted April 23, 2010 beware the transmission tunnel holes, they are the same BOLT SIZE as the rest, but the THREAD SIZE is not! standard threaded eye bolts will fit into the other 3 seat mount points, as well as through the bolt holes under the rear bench and into the rear wheel arches, BUT NOT the tranny tunnel, this applies to both EP91s and EP82s as i have found out with both my car and my bro's GT.can be a real pain, i resorted to drilling the tranny tunnel hole out, putting the threaded eye bolt through and gettin a nut onto the other side under the car.Phil. Quote
string Posted April 23, 2010 Author Posted April 23, 2010 yeah i understand that. So shall drill a new hole n bolt it that way. Obv theres 3 flat ish holes for seat frame. 4th goes into tunnel. My side mounts use existin feet of old frame. So that hole is used by seat frame. Can i use same bolt for harness then seat frame or is there another way? Cheers craig Quote
Amjad Posted April 24, 2010 Posted April 24, 2010 I think mine was done the same way as Phils, (it was fitted professionally).The bolt goes through pretty much right at the very end of the tunnel.The middle bolt is under the rear bench and the last one is by the seatbelt railHope that helps Quote
