^^ Just out of interest what boost did u run your ct9 at and what boost are you running your hybrid at?
my ct9 was mapped at a bar by the previous owner but i only ran it at 0.8 to be safe (although i had the boost controller off for a long time so it was at 0.5ish). that was mapped using a fcd and fpr setup.
my hybrid is set up on the emanage blue (also fitted by Nick @ TD), high boost is 0.96 bar and low is 0.7. Nick recokons that this would be around 195bhp (at high boost) but i'll have to get it rolling roaded to be sure.
even with the boost controller off the turbo seems to spool up a lot quicker than the ct9 did and the power is there whenever you need it.
