I have a front mount intercooler & also relocated my air filter behind the grille
Since fitting the fmic the car is drinking way to much fuel
Funds are a bit short to get the car remapped
I have a new fuel pressure regulator with the dial on the front
Would i be able to fit this in place of the factory one & turn the pressure down a bit
Any ides if this can be dont & what pressure should i set it to ?
Still running a ct9 turbo
Not a good idea to play with the fuelling without checking it with the proper equipment.
Just fitting the fmic shouldn't really make a difference to the fuelling unless you've now developed a lead foot?
Forgot to mention that the car is an auto.
I know that autos do use more fuel then the manuals.
Filled the tank to the rim the over week & headed down to devon
Driving under 60 mph with overdrive on , no boost at all
After 40 miles I noticed that it had done a quarter tank of fuel already !
