You could always run a cold air feed to the filter, cold air feed is basicly just i pipe that channels cold air from the front of the car to the filter, this will help with the hot air/ heat soak problem.
The filter in the pics looks like it should fit, but without measuring them you wont know, but i'd try it if i was in your shoes, you can always make it fit if it doesnt some how.
Jack
The One in the pic is a cone filter if you want to keep the stock airbox you need to get a panel filter namley k+N/TRD. the cone filter can be made to fit with a cold air feed, but IMO stock air box is best with panel filter unless you get a enclosed cone filter I.e a Bmc
Can you show me where you could purchase an enclosed cone filter?
