the pipe that jumps over the mani one that connection there keeps poping off every like 2days got 2 good jubiles on there aswell as the clips that wer suppleyed with the cooler ? was thinking of geting it welded or somthing
you cant weld it lol well not proper welding its alliminium so you'll have to get it ally welded but not a good idea
what intercooler is it? mine used to pop off when i tightened the jubilee clips as tight as i could get them.......with a screwdriver
im presuming their the clips that are a nut with a possie screwdriver slot in it. you tighten it up with a screw driver it wont be tight enough. try getting a socket on it i guarantee you can turn it another 5-10 turns. that will be tight enough
the intercoolers hold a lot of pressurised air theyve got to be as tight as you can get them matey
Mikalor clamps mate
Got the same problem
Just not got around to fitting them yet.
Jubalee clamps strech & thats why the pipes keep popping out
I have the same intercooler kit as you mate i just took the pipe off, ruffed the end up with some sand paper and it not popped off since just give it a good clean before you put it back on
