Anyone with an ep91 turbo live in or around the hull area need to try an icv off your car before i buy one to make sure this is my problem. would be much appreciated
Starlet don't have a mass air flow sensor they use a map sensor to read air flow it's a little black box onthe bulkhead drivers side and a 4mm tube coming out the bottom of it, it will be mounted higher than the manifold to reduce contaminates from getting inside it like oil it also has a small inline filter in the tube
Cheers bud i relise that now. An icv instead would be handy before i go buy one :)
