basically i finally recieved my bearing and fitted them to the block and main caps. crank turns fine when its sittin in the block and when the caps are placed on top but when the caps are tightened so just enough that both ends are flat on the block ( just a little past finger tight ) it wont turn anymore.
on the packs of bearing it says suited for toyot 1e , 2e. is that my problem or are they the same as 4e.
japfest doesnt look promising :harhar:
yeh they acl bearings. i put the middle cap on with arrow pointing toward timing side them put the other caps on starting 1 from the timing side so that all the numbers were facing the same way. thats the right way isnt it ?
only thing i could think of was how theres a small step in the block for the cap to sit into , the caps dont sit right in that untill i tighten them which would kinda squash it making it tight on the crank but i have 2 sets of caps and they both the same so im stuck.
