ashygt Posted May 18, 2010 Posted May 18, 2010 hi buying some wilwoods off a guy on here my only concern is will they fit on a mrk 1 gt because the hub is 54mm will 55mm be ok because thats what the wilwoods are well the 3g disks,also will they fit behind rota grids?stu Quote
Asad Posted May 18, 2010 Posted May 18, 2010 These off idrees? i think he got the them off CAT? who had them on his quad GT with 15" wheels......so i guess they would fit if yours is sitting on 15" wheels Quote
Keri-WMS Posted May 19, 2010 Posted May 19, 2010 It's not really ideal, you'll probably get vibration.The normal solution is to open the bells out to make room and fit a "ring" with w 54mm ID. You might be able to roll a centering "clip" from 0.5mm stainless sheet, bit DIY though.I wonder if the cheapest/neatest option here is to swap the hubs to the 55mm kind? (if it's possible, I don't know the hub bearing specs etc etc)Hope that helps. Quote
