I had to replace the rear shocks with KYB's due to an MOT failure. after doing this the rear top mounts came through into
the boot, which i know is a common problem. so i just replaced them.
After only a month of driving exactly the same thing has happened again!
i am starting to think maybe the springs are knackered and are leaving too much of the work to the damper.
anyone else had such a problem? any help would be greatful.
thanks
alrite mate my brother had this problem when we did his suspension on his civic, and it turned out that we hadnt put the washers back on correctly and they were sliding through, so dis-assemble them and put them back together making sure the washers and little stoppers are all back in place because if theyre not what you have described will happen
  • 1 month later...
