Dan Evans Posted June 20, 2010 Posted June 20, 2010 i put the new engine back in yesterday and connected as many of the cables and ports that i knew. im now stuck with the following and need to know were to connect them.;1.2. Small one one the right3.4. The one closest to the throttle body5.6. Need to know were both pipes go toand also, does this sensor just have a tube straight to the MAP sensor??(purple hose)any help will be much appreciated guys.cheers Quote
lukEp Posted June 20, 2010 Posted June 20, 2010 Right the green arrow pointing to a large pipe connection goes to the large pipe connection ontop of the Throttlebody which had a T-peice in between to a smaller pipe which goes to the green circle. theorange circle goes to my boostcontroler so ?then the red circle in the first picture goes to this red circle (feeds water to the matrix)the smaller pipe goes to the bottom of the Throttlebody (choke)this one goes to the other larger pipe on the first pictureand this one goes to the map sensor Quote
lukEp Posted June 20, 2010 Posted June 20, 2010 oh oh if i remenber correctly the small TB pipe goes to the charcoal fitler? Quote
