I recently fitted a jam fcd via the map sensor and yeah it does work but when driving about 20-30 mph it feels like the car is nudging but if i put my foot a little further its ok....the car is fine if i take the fcd off can any one please give me advice. Cheers help much appriciated
spec:
ct9 gt spec
hks filter
trd leads
ngk iridium plugs
zisco mildsteel mani
race tech decat
stainless cat-back
toytuning actuator set about .6
fmic
hdi boost controller set 1.0 bar
apexi safc 2
greddy boost gauge
how are you increasing the fuel, for the higher level of boost? seems you could do with a uprated pressure regulator. as when i had the safc, im sure it was increase the fuel pressure via a regulator and/or pump, and then use the safc2 to trim the fueling back a little??
i know its prob not the problem, as it seems to be the fcd, but its something for you to look into
