chr15_7_t_ Posted June 22, 2010 Share Posted June 22, 2010 wondering if anyone has had one fitted? or no if they will fit and if they are beter than the standard 4efte tmic? Quote Link to post Share on other sites
Danb Posted June 22, 2010 Share Posted June 22, 2010 the celica uses a chargecooler and not a intercooler so it wouldnt work...unless you converted yours to a charge cooler, but seeing as the gt4 people convert from chargecooler to intercooler i dont see the point. Quote Link to post Share on other sites
chr15_7_t_ Posted June 22, 2010 Author Share Posted June 22, 2010 cheeers Quote Link to post Share on other sites
ste91 Posted June 22, 2010 Share Posted June 22, 2010 the celica uses a chargecooler and not a intercooler so it wouldnt work...unless you converted yours to a charge cooler, but seeing as the gt4 people convert from chargecooler to intercooler i dont see the point.Water is a much more effective heat exchanger than air.Chargecoolers are actually "better" than air-to-air intercoolers in many ways, but I can't be bothered to go into detail. It is possible to use a chargecooler, but it's alot more expensive and complicated to set up compared to a simple intercooler core and a bit of piping. Quote Link to post Share on other sites
