The Toffinator Posted June 24, 2010 Posted June 24, 2010 As in the title, what sort of benefit would i get by decatting it?Thanks Quote
The Toffinator Posted July 12, 2010 Author Posted July 12, 2010 Come on guys! someone must be better with this stuff than me! Quote
wssoR Posted July 12, 2010 Posted July 12, 2010 You would get a small power increase, not much though. You may aswell remove the middle box aswell and get a less restrictive backbox to free up a few more horses. General rule with exhausts is less recstrictions = more power, stainless would be best.Hope that helps Quote
Asad Posted July 12, 2010 Posted July 12, 2010 tbh not many people decat with the standard exhaust its usually rusty and basically shiteif possible, go for a larger diameter cat-back and get a section with flanges put in to replace the cat. Quote
rob_bower Posted July 12, 2010 Posted July 12, 2010 ill have more info on this as i have something in the pipeline ill update asap!! Quote
rorenapier Posted July 12, 2010 Posted July 12, 2010 Properly designed silencers do not restrict power.@ japluva - From what you are saying , putting a 3" bore system with no restrictions and you would gain power? Dont think so buddyAs for going fo an uprated system, 2" would be big enough on a 4efe, any bigger and i would think you will lose power and torque Quote
wssoR Posted July 12, 2010 Posted July 12, 2010 Within reason I meant obviously larger is not always better Quote
durmz Posted July 12, 2010 Posted July 12, 2010 na's require some back pressure, dont go toooo big, as said, 2 inch system should work well Quote
rob_bower Posted July 12, 2010 Posted July 12, 2010 as a few people know ie been working on a 4efe stainless 4-2-1 mani and removeable decat for a while using standard size piping (this could easily be upsized to 2") these are readily available cheap in the 2nd hand market for as little as £15 depending on the scrap yard and are easily modded to fit!! using the standard front section!! well thats the theory anyway should have mine back this week and im hoping to try it on sat at the rr day!! aslong as it all lines up!!! fingers crossed!! sort the decat then if i have time!! Quote
