Raz Posted June 24, 2010 Share Posted June 24, 2010 On my diesel starlet it says NP90?whats this all about? Quote Link to post Share on other sites
ste91 Posted June 24, 2010 Share Posted June 24, 2010 N would be the series of the engine. Toyota's have the letter of the engine series then the letter of the actual car, for example the Supra, JZA80, the engine of course being the 2JZGTE. Quote Link to post Share on other sites
Raz Posted June 24, 2010 Author Share Posted June 24, 2010 Yes, the engine in mine is " 1N " Quote Link to post Share on other sites
ste91 Posted June 24, 2010 Share Posted June 24, 2010 That's also why the older Starlets are called KP instead of EP, it's the K series engine. Quote Link to post Share on other sites
Guest Enzo Posted June 25, 2010 Share Posted June 25, 2010 The n in np designates the chassis as the diesel has different mounting points,would be mint to get a turbo engined version found in a few jdm corollas. Iirc 1nt. Quote Link to post Share on other sites
Raz Posted June 25, 2010 Author Share Posted June 25, 2010 The n in np designates the chassis as the diesel has different mounting points,would be mint to get a turbo engined version found in a few jdm corollas. Iirc 1nt.I would like one as long as it doesn't take too much work. Quote Link to post Share on other sites
Guest Enzo Posted June 25, 2010 Share Posted June 25, 2010 in that case you would have to import the relivent corrolla II, tercel or corsa with th 1nt engine and swap everything across.id like one too,or even better a starlet with a yaris d4d engine would be the tits! Quote Link to post Share on other sites
Asad Posted June 25, 2010 Share Posted June 25, 2010 http://www.modifiedcars.com/cars/22586/mod...-pictures/32553thats what your after, epic project if you turbo it!! like so...http://www.toyotagtturbo.com/forums/showthread.php?t=56867 Quote Link to post Share on other sites
