JackStar Posted July 4, 2010 Posted July 4, 2010 Recently ive had a noise that sounds just like a boost leak, but the thing is that the cars running fine and is still boosting ok, the bracket on the top of the intercooler was broken which resulted in a silicone boost pipe being worn through, now the intercoolers fixed and ive replaced the silicone pipe, but the noise is still there, its a really high pitch squeal just like a boost leak. I cant hear it at full boost but that may just be as the exhaust is loud.I thought i was the bov leaking so ive changed that for one that was fine in my gt, but made no difference.Maybe a inlet mani gasket?Any help will be goodThanks Jack Quote
Lukew360 Posted July 5, 2010 Posted July 5, 2010 I get the same noise on mine, but still seems to pull hard on boost. I'm using the standard actuator. After removing my air box, that's when i heard the noise. I'm thinking its always made the noise, just i haven't heard it.Is it normal to hear this? Cheers Luke Quote
Vince#74-EP82 Posted July 5, 2010 Posted July 5, 2010 Worst case is oil in/through your turbo, as a wet turbo even slightly will whistly more as it spins up (when loaded) rather than on full boost Quote
daz27gt Posted July 5, 2010 Posted July 5, 2010 Try this,let your car idle and then cover your inlet on the turbo,if the boost pipes suck in and the engine dies u don't have a boost leak.if it keeps running you have a leak Quote
JackStar Posted July 5, 2010 Author Posted July 5, 2010 cool cheers mate i will try that tomorrow.Jack Quote
DannyGlanzav Posted July 5, 2010 Posted July 5, 2010 I have a high pitched squealing noise to when accellerating, I have checked intercooler pipes and replaced alternator belt but its still there but I think I have tracked it down to my fuel pump as the squeal is comming from the rear, I hope its not on its way out? Its very annoying sound Quote
Vince#74-EP82 Posted July 5, 2010 Posted July 5, 2010 ..but I think I have tracked it down to my fuel pump as the squeal is comming from the rear, I hope its not on its way out? Its very annoying soundBare in mind before diving in that Walbro fuel pumps generaly emit a slight buzz/wine. You may not have one but first check is there Quote
JackStar Posted July 5, 2010 Author Posted July 5, 2010 Ive got an uprated fuel pump but its not that.Jack Quote
Socks Posted July 6, 2010 Posted July 6, 2010 the walbro pumps r well loud! due to shite bearings! espically if your car is stripped very annoying....get a kit off tuning developments, same pump kit but better bearings longer warranty and alot quieter! Quote
DavidAshton Posted July 6, 2010 Posted July 6, 2010 I had a boost leak for about 6 months, took me sooooooooooo long to find.Car boosted fine, just made that boost leak wistle. In the end I replaced all the clamps and found the leak. So yeah dont rule out the intercooler yet, take it all off and refit, also check for traces of water in the pipes, thats how i found where mine was leaking. Quote
