Dan Evans Posted July 11, 2010 Share Posted July 11, 2010 drove the car all day, then on the way back home its missfiring like mad. i pulled over and let it idle, when you pull 1 &2 leads out its still idling, when you pull out either leads 3 or 4 it dies.all of them are still sparking, and I've swapped 3&4 plugs with 1&2 but its still doing it.its down on 2 cylinders ( 2 closest to cam belt) and im unsure as to what it could be.im waiting for my mate to txt me so i can try his dizzy cap.any ideas?? Quote Link to post Share on other sites
rorenapier Posted July 11, 2010 Share Posted July 11, 2010 How do the plugs look? Quote Link to post Share on other sites
Dan Evans Posted July 11, 2010 Author Share Posted July 11, 2010 look fine mate Quote Link to post Share on other sites
Guest ep82_girl Posted July 11, 2010 Share Posted July 11, 2010 mine done similar a little while ago. she completley lost compression in cylinders 2+3.dont wanna worry you but mine was a cracked head xxxx Quote Link to post Share on other sites
kane88 Posted July 11, 2010 Share Posted July 11, 2010 how bad is the idle and when u start it sound ok like it got compression Quote Link to post Share on other sites
Dan Evans Posted July 11, 2010 Author Share Posted July 11, 2010 seems to be cylinders 1 & 2 which arnt firing up, there seems to be good compression but i will be doing the test tommorow.il get new plugs and try leads @ dizzy Quote Link to post Share on other sites
kane88 Posted July 11, 2010 Share Posted July 11, 2010 yea do a test it happen to me but it was number 3+4 and it was the head gasket but it sound f**k when it tryinmg to start it Quote Link to post Share on other sites
