Dan Evans Posted July 12, 2010 Posted July 12, 2010 I've got no compression in the two left hand cylinders (cambelt side), no water loss, no banging or anything, i take it its the headgasket thats gone between the cylinders??? Quote
ToyotaTech15 Posted July 12, 2010 Posted July 12, 2010 Its more than likely head gasket,The chances of two sets of rings or two wrongly seated/sealing valves on two cylinders are pretty slim.Why has it gone so soon? anything obvious that could have caused it?Gary Quote
Dan Evans Posted July 12, 2010 Author Posted July 12, 2010 no idea mate, head was skimmed before being put back together same as the block, everything tourqued down correctly etc..i am running 1.1 bar on a CT9 on standard headgasket but i was told it could handle 1.2 with no problems???im going to get a 1.4-1.9mm Athena one now instead with ARP bolts. Quote
ToyotaTech15 Posted July 12, 2010 Posted July 12, 2010 Personally i would have run standard boost until it was all run it, and as you were that far down on the build i would have used an uprated head gasket and head bolts.It could have been alot worse mate, thats the way i would look at it.Gary Quote
Dan Evans Posted July 12, 2010 Author Posted July 12, 2010 only reason i didnt use uprated bolts and gaskets was due to me swapping the heads later on with a ported and polished one.il rip the head off tomorrow and make sure thats it, if so il get it repaired with ARP bolts and uprated headgasket and see how i get on Quote
ToyotaTech15 Posted July 12, 2010 Posted July 12, 2010 Ok fair enough,Good luck and hope that it can be back on the road in no time .Gary Quote
BenV Posted July 13, 2010 Posted July 13, 2010 when you fit the new arp head bolts torque them all up, put the engine through one head cycle and then lossen them off and re tourqe them this will stop the head from lifting and settle the studs nicley ben Quote
