big power on emanage blue. runnin hybrid at minute but in future going td04 or something similar. round 300bhp mark i hope. will my blue still cope or not?
Guest cheshireglanza
i no off a member running 1.4 bar td04 on emange blue so i would think you will be ok
^^ there's members off uksc running 1.3 bar on standard internals
you'll have to be forged for more than 1 bar of boost - also you wont get n e wer near 300bhp on a 4e with a td04 it'd be hard enough getting 300 on a 5e
You won't have to forge to go over 1 bar. In fact every Td04 kit i've done runs over 1 bar. (stock engines)
The engine doesn't make any difference to what a turbo will flow. The 5e will just make the power earlier in the RPM's than the 4e. Assuming everything else is equal.
i asked if i can run a td04 or 5 or rickys 300 kit on blue? Engine will be forged so what is it a yes or i gottb buy ultimate. Cheers
i give you the answer in the my first post
yeah i know. Wanted another person view aswell. Nick mapped ashy gts car on blue. Made 275 275 so i guess blues fine.
well if you run 1 bar on a td04 on a 4e it aint gunna make as much power as a td04 at 1 bar on a 5e
there aint no replacement for displacement
x2,
there is an e-manage forum for these questions here.
e-manage forum
you could run a blue up to any amount power theoriticaly, it has a 16x16 map so the only disadvantage is less mapping points over an ultimate.
a tdo4 is only really good for 1.45 bar,
with cams your looking at near enough 280-290.
