gingdust Posted July 21, 2010 Share Posted July 21, 2010 will i need to relocate the BOV once i fit a HDI fmic?if so do i need a reducer pipe and where can i get these?thanks Quote Link to post Share on other sites
Steve GT Posted July 22, 2010 Share Posted July 22, 2010 yeah the HDI FMIC pipes have the BOV pipe on the other side of the bay near the batteryPics: This is the reducer you wantIn the bayHope this helps Quote Link to post Share on other sites
jezza Posted July 22, 2010 Share Posted July 22, 2010 Depends on the diameter of your dump valve flange. I think the BOV pipe on the FMIC pipe is 34/35mm Quote Link to post Share on other sites
Josh@TunerLifestyle Posted July 22, 2010 Share Posted July 22, 2010 I've just fitted my jperformance one last nite and i beleve its a copy of the hdi kit, the dump valve pipe is 35mm and have had to order a reducer to get it to fit, hope this helps matey! Quote Link to post Share on other sites
gingdust Posted July 25, 2010 Author Share Posted July 25, 2010 thanks alot guys. im guessing if i choose not to put the BOV on, the hole just needs to be blocked, and may possibly get chatter?thanks Quote Link to post Share on other sites
Johnboy GT Posted August 12, 2010 Share Posted August 12, 2010 thanks alot guys. im guessing if i choose not to put the BOV on, the hole just needs to be blocked, and may possibly get chatter?thanksThe HDI FMIC bov outlet is 1 1/2" bud, bout 38 mm, you van get a reducer off ebay, I used racebikebitz ebay shop for mine.. About not using the bov, i dunno how that would work. Im pretty sure you need it? Quote Link to post Share on other sites
