fitting avensis calipers to corolla ... braking has improved
went out today and did it... much better braking! got them off a 1998 avensis 1.6.
you need the caliper, the carrier and pads,
carrier and caliper fits straight on to the corolla hub,
brake line bolts straight on to the caliper
you can use the corolla disc
(left is corolla, right is avensis)
(this was just a quick try, the pad sits properly, no touching lol )
u lov moding fella, i can tell, just sorry could not get you in the garage as it is full of all my projects at the min. (engine swaps, builds, and converstions). but we just missed the rain, was glad of that. and cam belt fella before you rolling road it plz.
will be in for that shortly lol...
just may need bleeding again... need to make them abit sharper if you can..
thats interesting, the piston looks a lot bigger,
im gona get a set when im next at the scrappys, thanx for sharing man,
nit mate, but im interestd in them like any other small toyota from the 90s
im pretty sure the caliper spacing is the same as on a starlet so they should mount the same,
good little addition mate will be interesting to see if they do fit a starbo
get some hammerite slapped on those calipers just to finish it off will look nice :)
Is that the AE101 shape? I have a 4-pot kit for that, we fitted it to a 3SGTE Woodsport-upgraded AE101 hatch a while back! Also have them for the AE82/92 earlier ones.
Geo, have you fitted your WMS EP 4pot kit yet dude?!!! It's your kit's first birthday soon! :)
yh its the ae101 shape but a 1.3 (ae101 are the 4age as far as i know)..
how much would they be?
It's £418.76+vat for the AE101 (and other Corollas with the same hubs) kit, that's the calipers/brackets+inserts/275x25 discs.
The Earls WMS/AE101-fit lines are the same price as for the EP (although not the same fit!) at £50.77+vat and the pads are the same as the other WMS kits, see www.ukstarletclub.com/forums/index.php?showforum=234 for more! :)
