paul mc Posted August 13, 2010 Posted August 13, 2010 need some advice changed king lead as it was worn changed spark plugs,dizzy cap,rotar arm and shes is still misfiring has anyone got any idea what i should try next ?? Quote
madmax_926 Posted August 13, 2010 Posted August 13, 2010 replace all leads bud give that a shot magnecores r fairly well priced on camskill im fairly positive this will fix your problem as i had the same thing Quote
Dan Evans Posted August 13, 2010 Posted August 13, 2010 does it sound like its running on 2 cylinders when on idle?? Quote
paul mc Posted August 13, 2010 Author Posted August 13, 2010 it already has uprated leads ngk ones i think dont know how old they are tho? Not sure if it sounds like its runningon 2 cylinders possiable but since i put the new spark plugs in it has made it alot more noticable . Quote
ibz Posted August 13, 2010 Posted August 13, 2010 you running a front mount intercooler? water may have gone into the sparks Quote
andieep82 Posted August 29, 2010 Posted August 29, 2010 could be one of your injectors not running correct fuel cycle Quote
james@cjperformance Posted August 29, 2010 Posted August 29, 2010 change your leads, if you dont know how old they are it will more than likely be them. Quote
Shorty Phil Posted August 29, 2010 Posted August 29, 2010 also check the earth on the left side of the inlet plenum mine worked its way loose and caused a missfire but also kept kicking my engine management light on and off worth a look never the less pal Quote
Markoos Posted September 14, 2010 Posted September 14, 2010 sorry to invade this topic but my car has suddenly started misfiring.Doesnt sound any different on idle but when im accelerating it judders and then accelerates.Anyone help? just ordered a new set of spark plug as havent been changed in a while Quote
paul mc Posted September 14, 2010 Author Posted September 14, 2010 check your king lead might be rubbing on something and worn away . Quote
jhonmathew Posted February 2, 2011 Posted February 2, 2011 Western countries are suffering the toxic combination of high debt, according to the above rules, workers with low incomes. The implicit debt to reduce the effectiveness of macroeconomic policies. Quote
