garbla900 Posted August 20, 2010 Posted August 20, 2010 right as most of you know im rebuiding my engine my self after a cracked head put the dampners on the engine. right my problem is i have a new head on which was bought from here and i got told that it was skimmed and everything was cool wih that but oil is mixing with the water some how ive tryed draining the oil several times ith a flsh through it but to no avail. im atmy wits end with this engine and i cant figure out what is wrng with it now. it worked fine before put the water pump belt on now im getting runny carmel coloured watter. any help much appreciated guys Quote
Asad Posted August 20, 2010 Posted August 20, 2010 new headgasket? how sure are you it was skimmed? got pics? could the block be fooked? Quote
garbla900 Posted August 20, 2010 Author Posted August 20, 2010 head was skimmed when i bought it mate and it a brand new head gasket th block was fine when i took the other head off it really fucking with my head now Quote
Asad Posted August 20, 2010 Posted August 20, 2010 Id whip the head off and see what the problem is....genuine headgasket? new headbolts? torqued to spec? Quote
garbla900 Posted August 20, 2010 Author Posted August 20, 2010 this the second head gasket because the last idiot never torqed the head bolts so ov we thought that was the prob but its still the same with the water mixing with the oil i think it could be the turbo seals or somfin......... its doin ma head in Quote
jezza Posted August 20, 2010 Posted August 20, 2010 not sure if this is even possible. I've heard of a few people getting the coolant pipes connected the wrong way round below the throttle body. Just a thought? Quote
Asad Posted August 20, 2010 Posted August 20, 2010 with that ^ why dont people just bypass the coolant from the throttle body sooo much easier just leaves two powersteering pipes to worry about Quote
garbla900 Posted August 20, 2010 Author Posted August 20, 2010 Any photos of them the right way round so that I can double check I have been silly with them. Would that put water in the cylinders thou o thought that was only cooling for the throttle body??? Quote
Russleh Posted August 21, 2010 Posted August 21, 2010 if thats not your problem et your block checked as i cannot rememeber where but im sure someone said blocks are just as bad for needin skimmed as heads Quote
Wantaglanz Posted August 21, 2010 Posted August 21, 2010 dont usually skim blocks just heads mainly, you just clean up the block with some sand paper Quote
garbla900 Posted August 21, 2010 Author Posted August 21, 2010 ive cleaned the head up apon checking everything else i think it may be the turbo thats at fault here cause the watter going to the turbo is fresh clean stuff but the oil in the return is carmel so i think it may be mixing in the tubo and getting spewed back in to the sump.any body local got a spare turbo or one ther not using that i can borrow for a couple of days to take my new one out and try that to fault find as you all know how frustrating this is and its been off the road for so long now that i just want it back and running getting fed up driveing an auto saab lol Quote
keirz Posted August 21, 2010 Posted August 21, 2010 it wont be the turbo, ive never seen the water chamber in the turbo crack allowing oil into the water. i highly doubt its this. if you really still think this could be the issue then run the turbo with no water lines. im 99.9% it wont be your problem Quote
garbla900 Posted September 1, 2010 Author Posted September 1, 2010 is there a way that i can check the oil pump???? i still no further forword with this and its cost me my gf and late for work on more than one occasion. helllpppp Quote
