ryan lang Posted August 22, 2010 Posted August 22, 2010 need some longer studs, and need some standard brake lines from the mastercylinder to just inside the arch, both front 1s are needed any help and linkage will be much appreciated, cheers dudes and dudettes Quote
Matt Glanza Posted August 22, 2010 Posted August 22, 2010 Sorry didn't ring u back Ryan been a bitch of a day.u cam get the longer studs on eBay.I think your only chance maybe to make new lines outa copper? Quote
ryan lang Posted August 22, 2010 Author Posted August 22, 2010 im gunna try toyota for the break lines, but ive tried a few hiace breakers for the studs, because i cant find them on ebayits not so much the lines themselves, its the little nuts that connect to the braided lines that just rounded off Quote
Matt Glanza Posted August 22, 2010 Posted August 22, 2010 I've got a few of them here from when I took out the and.type in Toyota extended wheel studs Quote
ryan lang Posted August 22, 2010 Author Posted August 22, 2010 would i be able to attatch them to my break lines?and ill have another look now dude Quote
Amjad Posted August 22, 2010 Posted August 22, 2010 You can definitely get the lines from Toyota, £11 a side or something like that! Quote
ryan lang Posted August 22, 2010 Author Posted August 22, 2010 they havent got any starlet extended wheel studs, only mr2 and corolla and for some reason they are like £1.99 and others are like £35 Quote
Matt Glanza Posted August 22, 2010 Posted August 22, 2010 They are the ones all u need to do is file down the splines to fit the starlet hubs Quote
