its time to replace my engine mounts but ive got the 6 speed box from a corolla G6 (bought the car this way) im thinkin of going for powerflex poly mounts but am unsure if these will fit because of the LSD, does anyone know if these mounts will fit on this box ? thanx for any advice you can give
the 6 speed box uses the same housing as the standard g'box. you should have no problem fitting the uprated mounts (i recently finished swapping my 5 speed for the 6 speed).
the mounts are the same its the brackets which are different, im planning on changing mine to soon.
You can use the 5 speed box brackets fine on the 6 speed.
mine might have been different because mine started its life as a auto :thumbsup:
Very well but I'd only recommend doing it if your doing an auto to Manuel convertionif your already 5 speed I'd recommend spending the money on an LSD
mine already a manual, i haven't been think about doing it i just wanted to know what the went like with a 6speed box in :thumbsup: Ill be looking into getting a lsd for mine after xmas :)
thanx 4 that
