Okay so what's the difference between ECON and the usual Air con button what's right next to it? They both seem to do the same thing! lol
If this has already been discussed before then I apologise in advance. I tried searching for it but couldnt find anything :thumbsup:
Ahhh economical air con then yeah? lol. Thats the only thing I actually thought it could be but then i didnt understand the point in having two air cons lol. Ahh well, glad thats cleared up! :thumbsup: Cheers pal
you got it :)
To explain the Economy mode a little more, the a/c compressor on the engine has a two stage control system. Usually the compressor runs at full capacity until the evaporators frost limit temperature is reached. As a result, if the heat load is low cooling will be excessive and a lot of power will be taken away from the engine. The economy system lowers the compressors utilization rate, when the a/c switch is set to ECON, the compressor is turned off when the evaporator fin temperature reaches 10 degrees C rather than the normal 3 degrees C. Thus saving the power that the compressor would normally use to reach the lower temperature
Hope tthis helps
Gary
I can't rip my air con out! It's too nice in the summer just to lose a little weight (I know its actually quite a bit of weight lol)
And now that I know fully that I can chill with my air con, economically! Buzzinzzz maaatttee!
Its also the power that it takles from the motor as well!!!!! also aides with space when fitting fmic :thumbsup:
Yeah I figure I'm just gonna put an Rx7 topmount instead. At the moment I want my car to be nice and reliable yet fast as well... Soon am just gonna go nuts and buy everything for it lol. Stay tuned! haha
