james@cjperformance Posted August 27, 2010 Posted August 27, 2010 i believe so....sure someone will be along to confirm Quote
Ryan5793 Posted August 27, 2010 Posted August 27, 2010 yes. headlights, brackets and grill. A few other things are also needed i think though. Quote
Tyron Devine Posted August 27, 2010 Author Posted August 27, 2010 yes. headlights, brackets and grill. A few other things are also needed i think though. such as bud ?? Quote
Ryan5793 Posted August 27, 2010 Posted August 27, 2010 indicator units, wiring and bulb plugs are also needed i think buddy. Im sure someone that has done it will clear this up though! Quote
mrkhan Posted August 28, 2010 Posted August 28, 2010 Yes they will, you need headlamps grill indicators bulbholders and the plug connectors from the other side of the wiring loom. You also need to cut the slam panel so the bigger units fit, theres a tutorial on it somewhere with good pictures. Ill have a look for it for you... Quote
Tyron Devine Posted August 28, 2010 Author Posted August 28, 2010 Yes they will, you need headlamps grill indicators bulbholders and the plug connectors from the other side of the wiring loom. You also need to cut the slam panel so the bigger units fit, theres a tutorial on it somewhere with good pictures. Ill have a look for it for you...thanks alot mate i need it asap ta bud Quote
chr15_7_t_ Posted October 10, 2010 Posted October 10, 2010 http://www.ukstarletclub.com/forums/index.php?showtopic=9585theres the tutorial dude Quote
