little lews Posted August 30, 2010 Posted August 30, 2010 What brakes fit on a starlet like a straight swap I've got 15inc wheels but i went bigger brakes has anyone ever done a straight swap if so could anyone give me a clue thanks Quote
Sanchez Posted August 30, 2010 Posted August 30, 2010 a straight swap? then a brake set up for a starlet would be a good place to start.Willwoods? Ksports? a 2nd hand levin conversion.. Quote
little lews Posted August 30, 2010 Author Posted August 30, 2010 a straight swap? then a brake set up for a starlet would be a good place to start.Willwoods? Ksports? a 2nd hand levin conversion..na mate like mr2 or gt4 braks is it possible Quote
Sanchez Posted August 30, 2010 Posted August 30, 2010 yes you can do a gt4 conversion, but they wont bolt straight on Quote
Sanchez Posted August 30, 2010 Posted August 30, 2010 have a look at thishttp://www.toyotagtturbo.com/forums/showth...ersion-complete Quote
little lews Posted August 30, 2010 Author Posted August 30, 2010 have a look at thishttp://www.toyotagtturbo.com/forums/showth...ersion-completewould i half 2 change the calpers ar thay a lot biger then the starlet 1s Quote
Sanchez Posted August 30, 2010 Posted August 30, 2010 the one in that link are twin piston levin calipers and disk, as apposed to the single piston starlet caliper.i had this conversion before i changed to willwoods Quote
little lews Posted August 30, 2010 Author Posted August 30, 2010 the one in that link are twin piston levin calipers and disk, as apposed to the single piston starlet caliper.i had this conversion before i changed to willwoodsar thay any good and could you tell me every bit i need please mate then ill rite it down how much biger ar thay then stander 1s thanks for the help bud Quote
5T4R7ET N/A Posted August 31, 2010 Posted August 31, 2010 Mate have a look at this, brake conversionsit has everything you need Quote
Keri-WMS Posted September 2, 2010 Posted September 2, 2010 The WMS 4-pot kits are another option, being direct-fit! Have a peek here or PM me if you need info etc: http://www.ukstarletclub.com/forums/index.php?showforum=234 Quote
