BoostJunkie Posted November 28, 2006 Posted November 28, 2006 just got a boost leak and dont even know where to start to look for it,it spools up fine boost gauge is reading normal doesn't dump anymore and there is a whistling noise(sounds like boost leak) coming from drivers side. oh and now drives like a 1.3. Quote
paul w Posted November 28, 2006 Posted November 28, 2006 Wind your window up! That'll stop the whistle! I can't see how you have a boost leak if it's still reading normal on the gauge?Is the gauge the one on the instrument panel or aftermarket? But then you say it drives like a 1.3? Try all the hoses and pipes around the dump valve/turbo.Either that or the dump valve is knackered! Quote
BoostJunkie Posted November 28, 2006 Author Posted November 28, 2006 only happened today. i dont understand it myself, i have an after market boost gauge that one is still reading normal but after you said about the gauge in the dash i went out and checked that one and it isn't lighting up anymore Quote
paul w Posted November 28, 2006 Posted November 28, 2006 Might be the actuator is knackered too,if that sticks open turbo will still spool up but car won't have any power so will be slower! Try a different dump valve if you can. Quote
BoostJunkie Posted November 28, 2006 Author Posted November 28, 2006 when me and my brother were looking at it,(i'm not a mechanic) i think there is a boost regulator on it which is connected to the turbo (obviously) but the jubilee clip that is connected to it is loose so it could be that hopin praying its that if not that then i will have to wait and see my brother scott whos a mechanic to look at itcheers mate appreciated Quote
BoostJunkie Posted November 29, 2006 Author Posted November 29, 2006 boost leak sorted checked all the intercooler piping and was way loose and tightened a jubilee clip that was connected to a valve that was next to the standard bov eveything is now fine, so cheers to paul w for his input and thanks for everybody elses help. LOL Quote
paul w Posted November 29, 2006 Posted November 29, 2006 No probs lad,stuff like that is usually somethin small like a loose hose. Every day is a school day! Quote
