Spuddy Posted December 1, 2006 Posted December 1, 2006 Anyone got experience using one of these? Had the car running about 1.2 bar boost and now can't get it to boost bast .5 bar, soon as i get to .5 the car judders and cuts power like mad really violently, when i switch off the boost controller it runs about .5 bar no problem with no juddering.Would the ECU need reset cause i was abusing the 1.2 bar map sensor? Quote
shelly_star Posted December 1, 2006 Posted December 1, 2006 what have you set your boost controller as? is it all set up correctly? Quote
Spuddy Posted December 1, 2006 Author Posted December 1, 2006 I dunno Settings from memory are cause i'm 100 miles away from the car lolBoost 70% (tried as low as 35%)GAIN 10% (Tried this at 5% and 20%)Start boost 136 (have tried this as low as 50)Warning 250These are just experimental figures not intended to be the final ones by the way.How important is the air filter piece? its not on there yet the guy that fitted it had it in his pocket and left! will fit it later this evening. Quote
shelly_star Posted December 1, 2006 Posted December 1, 2006 Iam not sure to be honest, but i'll tell you what my settings are on if it's any help, iam boosting about 0.7 bar on high boost. Gain 35%Set Gain 28Warning 115Warning % 0%Peak 123My car is standard near enough. That's what mine is reading. I aint reading it off the PSI mode. Quote
Spuddy Posted December 1, 2006 Author Posted December 1, 2006 I'll put these settings into mine and see what happens, prob will need changed some due to different characteristics of out cars plus mins a hybrid turbo fitted so will prolly mess things about!Cheers for the info though Quote
Spuddy Posted December 1, 2006 Author Posted December 1, 2006 Ok its not the Boost controller, put back on my Bleed valve and same problem happens, wonder have a blown the map sensor.Anyone know how to reset the ecu? Quote
Guest Enzo Posted December 6, 2006 Posted December 6, 2006 there is a diagnostics code list somewhere inthe technicalsection,maybe even pinned mate,sorry i couldent help you more Quote
ecksjay Posted December 6, 2006 Posted December 6, 2006 may be an injector or plug issue?try popping both out and cleaning, including leads and possibly the dizzy etc Quote
Spuddy Posted December 7, 2006 Author Posted December 7, 2006 Sorry taken me so long to reply to this.Was the plugs that where buggered, its running ok now though the boost controller is faulty too lol! Took it to the rollin road to get a health check, a reading and a sard regulator fitted and set correctly. Came back and they said they couldn't get 1.2 bar boost stable due to a fualty controler and charged me £100 for two hours work of what they called fault finding (which involved plugging in another boost controller, 5 mins i woulda thought) on top of the £250 for all the other stuff, I wasn;t happy i tell ya!Still they setting her up on the rollers for free for me next time so thats not too bad. Quote
