Hi everyone ! ! !
I just expereanced fuel cut for he 1st time :lol: (i think it was fuel cut) after fitting an air filter relocation kit
i've used the SEARCH button but couldnt find anythin about it but i'm sure i've read on here that fitting a relocation kit aswell as havin a decat can lead to boost creep,i've allso got an uprated fuel pump.
my gauge is sying its boosting to 0.9 bar with a standard actuator before it cuts
Am i rite in thinking that its the filter kit causing this and if so how do i over come it ?
Just fit an FCD or is there another way around it ? ? ? ?
FCD and Fuel Pressure Regulator, set it up at 0.9/1 bar :lol:
Also porting the wastegate helps a bit too or restricting the intake (though I assume you wouldn't want to do that?)
i'm goin to pick up a FCD tomoro :D
is there any point replacing the actuator for an adjustable one if its boosting to 0.9 on the standard one ??? dont really want to put much more than that through it with the standard manifold and internals
sounds like boost creep you can port the wastegate which should help. filters been relocated to the front grill i'm assuming??
I'd recommend a ported mani at least, the restriction is really bad!!
Yep defo get a HKS actuator, it will hold boost better and more scope for adjustment. Weird though that you're hitting 0.9 on a stock one, sure it's not a HKS?
Yea the filters behind the grill, i'm sure i've read before that tha can lead to boost creep but i couldnt find the topic on it, at least i know i havent messed anythin up lol
i've got a manifold lying round that i'm goin to get ported and its deffinatley a standard actuator.
Any idea where i can get the waste gate ported ?
hey mate i have an fcd for sale if your intrested hks one
Allready got one off my mate, swaped him for a few parts off my other strlet :thumbsup:
Cheers anyway tho
