Cali-BHC Posted September 22, 2010 Share Posted September 22, 2010 Hi Please i hope someone can help me.Using my car yesterday no problems, was leaving my mates and the car started fine and warmed up on, as i was driving away it started to hop, like i was in the wrong gear, then let out an almighty bang, so i pulled over and it was idling at 2k-2.5k.So switched it off and pulled it in somewhere safe, now when you turn the ignision on there is nothing. all electrics work, fuel pump primes, but nothing from the engine, no starter no attempt to tick over.There is still oil in the engine so it hasn't let it all go.Anyone have idea whats wrong, my car is my only from of transport to work so i'm facing losing my job if i can't find the problem.Thanks Quote Link to post Share on other sites
Socks Posted September 22, 2010 Share Posted September 22, 2010 that doesnt sound good! was the bang a misfire from the exhaust?check you dizzy and rotor arm, and spark plugs. make sure there all tight and your getting a spark...nno startermotor.. hhmm check all the fuses matey! Quote Link to post Share on other sites
Cali-BHC Posted September 22, 2010 Author Share Posted September 22, 2010 Cheers mate, Jump started it, runs but a bit rough. Starts fine when warm :/Changed the plugs but still running rough, dizzy has seen better days so going to replace that.If that doest cure it will change leads Quote Link to post Share on other sites
