If you're talking about stationary, mine does, but merely because I have poly bush engine mounts all around.
Problem? Hardly, stiff mounts = shake.
It might be the same with your car, only if mounts/bushes have been changed/replaced.
well im unsure if they are changed. the car is having a look over tomorrow by a mechanic so ill see then. cheers
