ollie ryan Posted September 27, 2010 Share Posted September 27, 2010 right i have no clue whats going on with my car this eveingi fitted my fmic yesterday and didnt drive it untill 20mins ago and when driving it just wasnt boosting right was hitting about 0.8bar but no dumpvalve sound and very very quite chatter i let it warm up then took it for a quick boot hitting bout 70mph tops and realised it wasnt boosting properly so headed home but got stuck at the train gates, where i noticed a hell of alot smoke comeing out of the exhaust and to be honest i thought my car was on fire there was so much, so i turned the engine off and gave it 3 or 4mins then drove home which was just down the roadi also fitted a catchcan yesterday so would this have anything to do with the smoke? and why am i loosing boost?im not going to drive my car again whilst i no this is going on so any help please would be fantastic as i dont want the starbo to go in flames thanks again guys Quote Link to post Share on other sites
LukeSR Posted September 27, 2010 Share Posted September 27, 2010 Check the intercooler pipes for any air leaks, most common problem when fitting a FMIC Quote Link to post Share on other sites
ollie ryan Posted September 27, 2010 Author Share Posted September 27, 2010 yeah i will check on the pipes but surely that wouldnt cause all the smoke aswell? Quote Link to post Share on other sites
LukeSR Posted September 27, 2010 Share Posted September 27, 2010 yeah i will check on the pipes but surely that wouldnt cause all the smoke aswell?Shouldn't no, i don't have a clue on that sorry bud :/ Quote Link to post Share on other sites
Craig_N Posted September 27, 2010 Share Posted September 27, 2010 With the smoke check the pcv valve hasnt broke or loose seen that happen before Quote Link to post Share on other sites
ollie ryan Posted September 27, 2010 Author Share Posted September 27, 2010 okay i will check that because i did spin it round to get the pipe onto the pcv and catch can Quote Link to post Share on other sites
Craig_N Posted September 27, 2010 Share Posted September 27, 2010 I think it could be that was there a hell of a lot of thick white smoke? Quote Link to post Share on other sites
ollie ryan Posted September 27, 2010 Author Share Posted September 27, 2010 yeah looked like something was on firethats the only way to describe it Quote Link to post Share on other sites
Ryan-11 Posted September 27, 2010 Share Posted September 27, 2010 I did u take a pipe from the breather and a take a pipe from your pcv valve and put them both into the oil catch tank? how many ports are on your catch tank? does it have a breather filter? does it smell like burning oil? do u have any pics of how your catch tank is connected? Quote Link to post Share on other sites
ollie ryan Posted September 27, 2010 Author Share Posted September 27, 2010 got one pipe going from the breather to the catchcan then a pipe off the pcv valve into a seperate port on the catchcan and io have no breather on the catch can Quote Link to post Share on other sites
Ryan-11 Posted September 27, 2010 Share Posted September 27, 2010 got one pipe going from the breather to the catchcan then a pipe off the pcv valve into a seperate port on the catchcan and io have no breather on the catch canthats the problem then mate, u need to have a breather on the catch tank, if both pipes are connected into the oil catch tank then the engine isnt breathing and building up pressure and causing the oil to get past the piston rings and burn off, thats why its smoking. Quote Link to post Share on other sites
ollie ryan Posted September 27, 2010 Author Share Posted September 27, 2010 thats the problem then mate, u need to have a breather on the catch tank, if both pipes are connected into the oil catch tank then the engine isnt breathing and building up pressure and causing the oil to get past the piston rings and burn off, thats why its smoking.ah okay so shall i just leave the pipe to the catch can from the breather on then get rid of the one from the pcv valve and fit a breather on the catch cans second port? Quote Link to post Share on other sites
Ryan-11 Posted September 27, 2010 Share Posted September 27, 2010 ah okay so shall i just leave the pipe to the catch can from the breather on then get rid of the one from the pcv valve and fit a breather on the catch cans second port?yeah just put the pcv valve back into the inlet, yeah put a filter on. Quote Link to post Share on other sites
nastyrash 2003 Posted September 27, 2010 Share Posted September 27, 2010 the corect way to conect the catch can is to put the large port into the main oil breather pipe, ie the pipe on the top of the rocker cover that went to the original efi pipe (recert valve), and the small port to a pipe going to the air filter relocation pipe going into the turbo, remeber u want vacume (negative presure) never booste presure going thrw the catch can. Quote Link to post Share on other sites
nastyrash 2003 Posted September 27, 2010 Share Posted September 27, 2010 were is the smoke coming from fella (under bonnet or out the exhaust), is the engine missfiring, check your oil level and has it droped, check your water level has it dropped, Quote Link to post Share on other sites
ollie ryan Posted September 28, 2010 Author Share Posted September 28, 2010 is it safe to run wthout a breather for a few days?i have put the pcv valve back onto the inlet mani and the rocker cover breather is going onto the catch can but the other port is now open to the atmosphereis this safe for a few days? Quote Link to post Share on other sites
ollie ryan Posted September 28, 2010 Author Share Posted September 28, 2010 is it safe to run wthout a breather for a few days?i have put the pcv valve back onto the inlet mani and the rocker cover breather is going onto the catch can but the other port is now open to the atmosphereis this safe for a few days?any no if its okay? Quote Link to post Share on other sites
nastyrash 2003 Posted September 28, 2010 Share Posted September 28, 2010 any no if its okay?yep mate but put a little filter cap on it the pvc valve will suck and air will flow through the open port like it is designed to just put afilter on it so it does not draw dirt into the engine. Quote Link to post Share on other sites
nastyrash 2003 Posted September 28, 2010 Share Posted September 28, 2010 i have a pvc fetish u see. lol, i ment pcv Quote Link to post Share on other sites
PJ Johnson Posted September 28, 2010 Share Posted September 28, 2010 i fited 1 the other day it only got 1 pipe going to top of rocker cover is that wrong Quote Link to post Share on other sites
ollie ryan Posted September 28, 2010 Author Share Posted September 28, 2010 thats okay thengoing to take the intercooler pipes off again this wekend as i have tightened them all up but still have a boost leak and i want to hear my chatter Quote Link to post Share on other sites
nastyrash 2003 Posted September 28, 2010 Share Posted September 28, 2010 i fited 1 the other day it only got 1 pipe going to top of rocker cover is that wrongif your talking about a catch can, thn yes it will not be going any thing, but if u have the pvc valve in place thn the engine will breath adiquetly. Quote Link to post Share on other sites
ollie ryan Posted September 29, 2010 Author Share Posted September 29, 2010 right i have checked every pipe gloing for the intercooler and still a massive boost kleakdoing my head in now Quote Link to post Share on other sites
nastyrash 2003 Posted October 2, 2010 Share Posted October 2, 2010 right i have checked every pipe gloing for the intercooler and still a massive boost kleakdoing my head in nowdid you get my number fella give us a bell and i can talk u thw a few checks. plus check your waste gate has not dropped open, and iz it still smoking. Quote Link to post Share on other sites
ollie ryan Posted October 2, 2010 Author Share Posted October 2, 2010 nice one mateyeah got your number in my phoneand its not smoking anymore was just the way i set the catch can up Quote Link to post Share on other sites
