I'm currently trying to get my GF's 1998 Starlet Sportif1.3 through it's MOT, and it failed on rear brakes imbalanced and ineffective
I've bought the brake shoes, but i can't for the life of me see how to remove the actual drum
All i can see is 2 10mm bolts on the back that seem to hold the brake pipe in place, then a rubber grommet just below it
Cheers
Rich
ive taken them apart afew times jack it up put on acel stands! etc take the handbrake off and the front part just prizes off but its a rite pain in the arse, i usually use a flat headed screw driver to stick in the gap to slide it off, the pads will still usually grab the drum even with the handbrake off.
wee tip is to get the middle nut off then put the wheel back on with 2 nuts and it gives ya loads more leverage. bit fidly changin the shoes. just takin everythin off and puttin it back the same
