GlanzaJim Posted September 30, 2010 Posted September 30, 2010 im coverting my sportif engine to the 4efte glanza.but i need to know what exactly what i need for this as i have not a cluecan anybody help thanks Quote
Guest cheshireglanza Posted September 30, 2010 Posted September 30, 2010 glanza dash loomglanza engine loomthe engine lolturbo mani decat off turboglanza fly wheel if your using your na gearboxglanza clocks Quote
Russleh Posted September 30, 2010 Posted September 30, 2010 ull need the light and wiper stalk unit thing aswell. to be honest u need pretty much everythin from the car that is remotly connected to the engine lol. Quote
adz_sportif_turbo Posted October 6, 2010 Posted October 6, 2010 there are a few ways of doin it,,,i just have a fte engine and loom,,,cross referenced the pin outs on the ecus and spliced it in!! not the recommended way lol. apparently u can use a ep82 engine and loom as its 2 plug like an N/A,,,or u jus basically re shell a glanza into a sportif,,,probably the best way Quote
JackStar Posted October 6, 2010 Posted October 6, 2010 i did as adz sportif turbo said and used just the 4efte engine and loom and made it fit the ecu plugs ive got all the pin outs you may need, if you want, will also need the ingintion amp and turbo map sensor. Give me a shout if you want a hand, we could nick the bits from your bros glanza when he gets it lol.Jack Quote
