best way of blanking for chatter?
Is you BOV adjustable? If so thighten the spring and get chatter on low boost and dump on high. Best of both.
If it's not adjustable, find a blanking piece with suitable diameter and jubilee onto the silicone hose on the intercooler pipe. You can put a self tapper or small bolt in the end of the vacuum pipe to block it off.
thats ideally what i want with my BOV. I have a HKS BOV, that is adjustable, but no chatter at all. when i adjust the screw, not alot changes.
its not a HKS 2, looks smoother a slightly bigger? is it a possiblilty its worn out the spring? really want the high pitched 'chirp' of a HKS but its no where near that, really deep sound :mellow:
cheers
ive got a hks ssqv old style and the adjusting screw didnd do a thing, what i did is take it apart which is simple and stretch the spring about 10-15 mm and on the ct9 sounds mental chatters like mad with the high pitch tssshhh at the end, unfortunatly it doesnt chatter on the td04 but ct9 sonds mental!! :mellow:
thanks buddy! i will definately try this as i think it is the old style HKS. definately is genuine. thanks dean
you can normally add a spacer to increase spring tension or coil an additional spring with the existing one.
this would be ideal. been searching for something like this but cannot find a thing, any ideas where i can get a spring mate?
thanks
