gingdust Posted October 1, 2010 Share Posted October 1, 2010 have a HDI FMIC and wanna mess about by blanking the 35mm BOV hole for chatter.was wondering the best way of doing this and where should the pipe from the inlet manifold go? blanked aswell?thanks Quote Link to post Share on other sites
jezza Posted October 1, 2010 Share Posted October 1, 2010 Is you BOV adjustable? If so thighten the spring and get chatter on low boost and dump on high. Best of both.If it's not adjustable, find a blanking piece with suitable diameter and jubilee onto the silicone hose on the intercooler pipe. You can put a self tapper or small bolt in the end of the vacuum pipe to block it off. Quote Link to post Share on other sites
drew 007 Posted October 1, 2010 Share Posted October 1, 2010 ^^ I believe it does matey as it will mess around with the idling of the car, if left open to atmosphere. Quote Link to post Share on other sites
lukEp Posted October 1, 2010 Share Posted October 1, 2010 Just take the vac pipe off the bov and stick a screw in the pipe for now so you can listen to the chatter. Quote Link to post Share on other sites
Sanchez Posted October 1, 2010 Share Posted October 1, 2010 You can buy intercooler blankers off ebay Quote Link to post Share on other sites
gingdust Posted October 1, 2010 Author Share Posted October 1, 2010 Is you BOV adjustable? If so thighten the spring and get chatter on low boost and dump on high. Best of both.If it's not adjustable, find a blanking piece with suitable diameter and jubilee onto the silicone hose on the intercooler pipe. You can put a self tapper or small bolt in the end of the vacuum pipe to block it off.thats ideally what i want with my BOV. I have a HKS BOV, that is adjustable, but no chatter at all. when i adjust the screw, not alot changes.its not a HKS 2, looks smoother a slightly bigger? is it a possiblilty its worn out the spring? really want the high pitched 'chirp' of a HKS but its no where near that, really deep sound cheers Quote Link to post Share on other sites
ollie454 Posted October 1, 2010 Share Posted October 1, 2010 where did you get it from mite be a copy mate Quote Link to post Share on other sites
gtmuzz Posted October 1, 2010 Share Posted October 1, 2010 I've got a wheel nut in the pipe my dumpvalve used to to be attached to using a jubilee to hold it tight so it doesn't shoot out lol Quote Link to post Share on other sites
Dean @RW-Developments Posted October 1, 2010 Share Posted October 1, 2010 ive got a hks ssqv old style and the adjusting screw didnd do a thing, what i did is take it apart which is simple and stretch the spring about 10-15 mm and on the ct9 sounds mental chatters like mad with the high pitch tssshhh at the end, unfortunatly it doesnt chatter on the td04 but ct9 sonds mental!! Quote Link to post Share on other sites
jezza Posted October 1, 2010 Share Posted October 1, 2010 you can normally add a spacer to increase spring tension or coil an additional spring with the existing one. Quote Link to post Share on other sites
gingdust Posted October 1, 2010 Author Share Posted October 1, 2010 ive got a hks ssqv old style and the adjusting screw didnd do a thing, what i did is take it apart which is simple and stretch the spring about 10-15 mm and on the ct9 sounds mental chatters like mad with the high pitch tssshhh at the end, unfortunatly it doesnt chatter on the td04 but ct9 sonds mental!! thanks buddy! i will definately try this as i think it is the old style HKS. definately is genuine. thanks deanyou can normally add a spacer to increase spring tension or coil an additional spring with the existing one.this would be ideal. been searching for something like this but cannot find a thing, any ideas where i can get a spring mate?thanks Quote Link to post Share on other sites
