my third starlet and it always happens in the drivers side. It comes in from where because neither of them had any rust.
check the window seals and sunroof seals (if you have one)
since think the seals on my boot are either knackered or not on correct since first night it rained my boot filled up with water
On my old car, the top of the windscreen was letting water in, it was running down the pillar and out at the bottom in the foot well.
Used a bit of black silicone squashed in between the seal and screen, that did the trick :mellow:
Guest chezyboiiiiiiiiiiiiiiii
it looks like its coming from behind the dash but its not wet up behind the dash and all round the windscreen is dry :D
try the seal where the looms connect together cuse that cud be fuked its behind the dash where the interior loom meet and the engine loom meet :lol: hope this helps n i want your exhaust but no body knows if it will fit B):lol:B)
  • 3 weeks later...
FOUND IT !!!!! :p
it was a gromit under the scuttle panel, it fell through and was in the heater motor up under the dash was a bastard to get out but now no more leaks :D thanks for the help
